HELP! Wierdness @ Startup
Lower Balljoints on 4WD
Throttle cable recall
Everytime I get in my truck and try to drive it now, it seems to have 10% of the power for about 5-10 minutes. After I finally get pi**ed off and floor it without shifting, "something" decides to work and I nearly break my neck or run over someone. It seems like my PE COMP is keeping my VP44 from running right and then it senses the boost is "up" (and by up, I mean 7-9 psi) and then decides it wants to go. I turned the COMP off and then it sometimes runs fine, and sometimes doesn't. I've tried changing the level of fuel added and also the time @ which fuel is added and nothing helps. I'll probably end up calling EDGE, but I wanted to see if any of my fellow "CUMMERS" knew what the heck was going on.
TIA,
Eric
Just as a simple quick check, what is your fuel pressure after filter when it is acting up. The basic stuff if overlooked can really bite anyone in the rear.
BG's running good
My fuel pressure is @ 14 psi ALL THE TIME. I was one of the lucky ones who's BG stuck with it.
Thanks guys, I'll try unplugging it and see what happens.
