Engine/Transmission (1998.5 - 2002) Help with Code PO238
Engine/Transmission (1994 - 1998) 12V in Chevy
2nd Gen Non-Engine/Transmission need a bigger radiator
Can someone tell me what to do to fix this code, the engine lite stays on and it shows code PO238. something to do with the map sensor I think ? Mark
Mark,
It’s probably the MAP sensor, but the only way to know for sure would be to measure the boost pressure (with a gauge) and compare that to the pressure being reported by the ECM over the OBDII port using an appropriate code scanner.
The simplest thing to do is to swap out the MAP sensor and see what happens. If that doesn't solve the problem, well at least you have spare MAP sensor. :)
John L.
