I am about to try to set my own pump timing and was curious if the pump will possibly move when i pull the gear and if it does what is the best way to move JUST the pump back to the spec im trying to achieve. Do i have to put the gear back on and turn the engine or... . ? This is goin to be my first attempt so any help or suggestions will be helpfull. I have all the tools, dial indicator specs, etc.
Has any one ever pulled the pump off and notched out the 4 hold down bolt holes to adjust the pump by turning it instead? i used to turn the stanadyne pumps to fine tune the older GMC's I know there wouldnt be much room to turn it but alittle may make a difference.
