2nd Gen Non-Engine/Transmission Hi Idle
2nd Gen Non-Engine/Transmission LMC headlight harness question
2nd Gen Non-Engine/Transmission New rear springs on my 2001 1500
Update; Got the hi idle turned on and it works great. When it switches to 3 cylinders, look out, cause it sounds like it is going to come apart. Just wondering what really happens when the 3 cyl kicks in. Im guessing the computer shuts off fuel thru the vp44 to the cylinders that are not firing? Thanks, Moe
Yep, fuel is cut to 3 cylinders forcing the other 3 to work harder to drag the "dead" ones. Did you ever get a high idle box from ProWelder?
Hey d4l, I got a controller ordered but he is behind in getting it made. Said it would be here around the 1st of Feb, Moe
Well the good news is if its anywhere near as cold where you are as it is up here, the high idle will kick up on its own no problem. Its been below 0 the last few nights
D4L. It sucks to live in Ohio in the winter, and yes its very cold here too. Ive worked outside most of my adult life ( telephone company) and I use to have some tolerance to the cold. Now that Im older and retired I just cant stand it at all. Moe
