What caused you to trade the Ram 5500? Did you grow tired of the stiff unloaded ride?
The engine will automatically idle up to 1000 RPM after 2 minutes of idling if it's cold enough outside and your coolant temperature is below 180F. It also has an idle-up feature that you can set using the cruise control... nothing the dealer has to set for you.
Joe,
I regret you had that expensive experience. As I have written several times, I wanted and planned to buy a Ram 4500 but was afraid it would ride too rough as a daily driver and I would eventually hate it.
A Ram 4500, if devoted to hauling a heavy slide in camper or pulling a heavy fifthwheel, makes a great tow or hauling truck. I use my Ram 3500 as a daily driver and although a little stiffer than a pickup, it rides pretty well. Well, I did until I bought a Goldwing, but I don't drive it much now.
What kind of milage you getting towing that big 5th wheel???
The high idle is no longer available with the manual transmission.
The dealer spent a couple of hours trying to enable it on my '10. They finally called Star and were told it was not available any more for the manual transmissions.
I don't know about the C&C's.
Guess I would have to come with my own creation on the high idle. What about cold weather features will they idle up like my second gen. does?
Harvey,
I know my second gen will step up when it's cold enough, just was curious about the 4th gen doing it.
