My 99' has an HX-35 12cm2 turbo. I followed the manual by using a gauge to measure radial bearing clearance. The turbo is in spec. , but just barely..... noticeable play when moving the impeller up and down. How long can this turbo hold up as a daily driver. What symptoms will show (i. e. noisy bearings, oil leak, etc. ) when it is near the end of it's service life? Will a well worn turbo hold down boost? I've checked for leaks and cannot get over 17 lbs. of boost when hauling 7000lbs. of horses @ WOT up a 6% grade.
Thanks in advance!
Bill
Thanks in advance!
Bill
