Hello,it's been 8-10 degrees in CT. and heading towards -10 overnite. I've got my truck plugged into a heavy-duty timer that turns on at 3:00am and i leave the house at 6:30,is that too long for the truck to be plugged in or should it be set to go on earlier? Is it safe to keep it plugged in ALL night when it is expected to be less than -10 before the wind chill? I use 8oz. of FPPF "Total Power" before each fill up and my batteries are up to par,so initial start up is not a problem,so far. Is it ok to leave plugged in while truck first starts up and sits at an idle for 10 minutes. I would think this would speed warm-up time. Correct me if im wrong
My power steering pump sure does ***** n' moan for the first 15 minutes while warming up,pump reads full,is this normal for a diesel in the same weather conditions? Thanks
