How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
now have 80K on my 99 2500 4x4.
3 lp's, 3rd one did small line relocation kit.
2 rear drive shaft TC seals.
1 rear drive shaft, yoke eating seal. Thinking need new hanger bearing now.
1 VP44
1 track bar / change to gen 3 bar.
1 set of shocks.
1 set of batteries.
Many sets of front pads.
1 set rear shoes, hardware and cylinders.
1 exhaust system.
1 seat motor
1 headlight switch
1 AC condenser right outside of 3 year warranty. (maybe need another now).
1 oil pan
3 sets of tires, will be going for the 4th soon.
Front brake hoses, last year lost a hose when backing into driveway... 'eeewww . nice place to loose one if you have to loose one.
In the last month. .
Last set of pads, one eat 1 side of a rotor so:
Pads
Rotors
Unitized Bearings (and associated hardware)
Pads
Calipers (one boot had a slit) and hardware.
200,044
transfer case rebuilt
dana 80 rebuilt
injection pump
in cab wiring harness
3 set of tires
clutch
rear main seal
both front hubs
ball joint
5 track bars
oil pan gasket
for the love of the Cummins
i have 250000. klms on my 01 2500 and 142000klms on my 01 3500 and the only reason i put up with these trucks is because off the cummins. i would need 10 treads to tell you off the parts that i have put on the front ends off these trucks. and they still handle like a unicycle.
But as long as those old masculine clunkin cummins keep rattleing i`ll try to keep a front end on the truck ha ha ha ha ha
2002 Dodge 24 valve ho (miles on my truck)
well i have to say that my 02 truck just rolled 288950 miles:):
I have done the following repairs myself
A) Replaced both from wheel bearings#@$%
B) Replaced (1) track Bar
C) Replaced (4) Brake Calipers
D) Replaced Injection Pump (1)
when i replaced the injection pump i purchased a Fass Fuel System
(best thing i ever did):
E) Upper and Lower Ball joints#@$%
i dont think that is too bad for having 288950 miles on the truck:)
we just got back from Colorado with the truck (Ran Great):):cool:
but now i have a bad noise comming from the front:mad:
i have done the following modifications to the truck
Fass Fuel System :)
RV Injectors
Five Inch Exhaust from Turbo Back
Super Chip (not impressed):mad::mad::mad:#@$%
Custom two stage Air Intake
ARP Head Studs
Port/Polish Head
Boost Fooler
Pratshaft 64 Turbo
I want to start pulling the truck and plan on replacing the Clutch and purchase an EDGE Comp Box
Building a set of tractin bars
install a better injection pump
building a set of drive shaft hoops
so if anyone has information let me know
thank you
Mark,
01 3500 work truck-285,000 miles. 1 lift pump,2 apps,1 clutch at 256,000,rear end,normal maint. items. seems odd all the problems others have with way less miles.
2001 3500 4x4 6spd HO bought the truck used with 101,000. Brakes had just been done, nothing else was mentioned IE; original clutch, VP44, lift pump. Replaced APPS around 120,000, front rotors/ pads around 200,000, currently needs another APPS but avoiding changing it because it works most of the time. Discovered bad lift pump this morning after fuel filter change 210,000. A/C fan switch only has high,and low no middle. Topped off A/C around 205,000. Other than the APPS I am really happy with the truck. I would have thought that the APPS would have been taken care of/redesigned as a saefty issue.
Check with Genos about an aftermarket APPS that is better then stock
Mike
Thanks Mike, I will check into that. I think what burns me the most is that you have to buy the entire bellcrank assembly, instead of just the sensor. I was starting to wonder if a different generation part woild work better, and could it be adapted. , but that subject is for another thread... ... ... ... ... ... ... ...
2002
2002 with 194,000 miles. Injector pump at 92,000 miles, Goerand transmission at 108,000 miles and APPS at 192,000 miles. Replaced lift pump with FASS system before it could fail. DWest
knocking on 142000 miles. replaced lift pump with fass system at around 130000. water pump, t-stat, and altenator last month. other than that no problems.
My '99 3500 has 261,083 miles on it. My '96 has 221,345 miles on it. I drive the '99 daily, my son is now driving the '96 2500 daily.
I hope to drive the '99 until it drops out or I do!
Big John
update
313,000 miles on my '01. Still original water pump, haven't had any issues with TPS, but may have vacumn pump starting to leak. Injection pump replaced, South Bend clutch installed, rear axle seals. 17. 85 mpg for every mile driven.
