How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
Back -up light switch 24000 miles
Steering box (wander) 34000 miles
Lift Pump (11 psi idle, 7 psi load, 3 psi WOT) 48000 miles
All repairs covered under warrenty
Just terned 200K this month. 3 lift pumps, one main pump(167K) lots of tires and brakes, otherwise runs great with 17-19 mpg. Dave :)
68,000 nothing major as of yet. (Of coarse now I'm knocking on wood) Just last weekend I was thinking how happy I've been with this truck. I'm on my first diesel and could'nt ask for more. I drive her like I stole it, I pull hard through hay fields, pastures, loaded averaged at or over 21,000lbs. ( thats loaded trailer only) hauling round bales. I know I'll need to do more on the up grades soon but I'll keep the right foot down cause I know the truck can handle it.
Turned 175,000+ today!
Turned 175,000+ today! :D This thing just keeps smokin'... I mean going! :-laf
1 lift pump at 84,000 - $0
1 lift pump at 130,000 - $164
1 VP44 at 136,000 - $1500
Driving like you stole it for 175,000+, - Priceless
Ramtough, It's in your steering colum, call up your dealer and ask them. There was a recall on it, I got my recall right after I bought the truck.
187,832 mi to date. Two lift pumps, one clutch, fifth gear nut twice (now I have the fully splined shaft), one accelerator pedal position sensor, and one rear wheel speed sensor.
47000 on 2001, injector pump failure at that milage. Suspect Power Puck contributed to its early demise. Covered under warranty :-laf
Otherwise truck has been painless.
I have 116,000 on mine. Orignal automatic, pump went at 100,015 miles. Dealer warrenteed it and replaced lift pump as well. No other mechanical issues runs great.
I'm at 260K now
3000 put in 100HP injectors and guages
71000 lift pump
82000 clutch and rear main
88000 exhaust manifold
92000 head gasket
100001 edge comp(no pump wire), BHAF
160000 lift pump, max flo kit
221000 lift pump, pusher pump, pump wire, 4" exh.
221001 ordered SB Con OFE
245000 APPS started acting up, cleaned it
257000 water pump
31800
31800 miles on mine, 1st thing I did when I got it home at 22900 fuel guage than at 26000 pusher pump, running great.
106,000 on my 99
2 lift pumps (ouch! as I am my own warranty station!)
and a complete ATS transmission
Other than that mostly wear and tear items. I drive it hard and tow heavy and love the truck!
Current mileage: 28,500 miles
Problems since new:
Clunk in steering column: Warranty replaced
Reverse light switch on side of 6 speed transmission: Warranty replaced
Door lock cylinder switch (Service bulletin): Warranty replaced
At the moment it is in the dealer for the sun glass
holder door tab that broke and a powersteering
pump that is bad: Warranty is replacing
