I'm looking for the max travel trailer weight for my truck and I can't seem to find it in the owners manual and the Dodge website says I can tow 15050, but I'm assuming this is for the dually version of my truck with a gooseneck or 5th wheel. Here's what I have:
2007 3500 Mega Cab
5. 9L Cummins
Single Rear Wheel
3. 73 gears
G56 6 speed manual
Towing Package
Weight distributing hitch
The Dodge website says "Towing capacities may vary. Consult your dealer to for full details on the towing capabilities of the vehicle. " but since I knew about the 6. 7 long before they did, I'd rather hear it from someone on here that I can get an accurate answer from. I remember my '03 2500 long bed quad cab had a sticker that said I could tow 12500 or 13500 I can't remember which.
I'm looking for the weight the truck is legally certified to tow, not what it is capable of towing in an overloaded state.
Here's what the Dodge website says:
With 3. 73 Axle Ratio You Can Tow 15050 lbs
Gross Vehicle Weight Rating(GVWR)=10500
Payload=2690
Curb Weight=7810
Curb WeightFront/Rear=4470/3340
GAWRFront/Rear=5200/9350
Gross Combination Weight Rating(GCWR)=23000
Look for the Equipment Identification Sticker to identify your vehicle's Axle Ratio. If you are unable to determine your vehicles axle ratio, assume you have the numerically lower ratio and can tow the lesser of these ratings.
While it's not listed in the charts, tongue weight is also an important consideration. The recommended tongue weight is between 10 & 15% of the trailer weight. However, the maximum tongue weight on Class III (The bumper ball) is limited to 500 lbs, and Class IV (The receiver hitch) to 1200 lbs.
This requirement overrides any recommended GTW rating, between 10% and 15% of gross trailer weight (GTW). Additionally, the GAWRs and GVWRs should never be exceeded.
2007 3500 Mega Cab
5. 9L Cummins
Single Rear Wheel
3. 73 gears
G56 6 speed manual
Towing Package
Payload=2690
Curb Weight=7810
