Hrmm. . had not thought about that possibility at all and it sounds very possible.Hohn said:There's another way to look at this.
There's an expansion chamber effect to be considered that may explain the reading given by DHayden's testing. If the exhaust manifold is significantly larger than the exhaust port runners (by volume) then the exhaust gases will cool as they expand into the manifold.
So it's quite likely that the EGT drop seen onthe pryo is NOT the result of any enhancement in airflow. It could be explained by the expansion of hot exhaust into a larger volume conduit. This expansion will cause the gases to be cooler, denser, and lower velocity.
How so? maybe you are thinking if the pyro is in a runner vs down by the turbo inlet??So your pyro might be getting fooled by the expansion of exhaust into the larger manifold volume.
I see, so you are assuming he is measuring boost at the intake manifold where the expansion would result in a temperature and pressure drop. Geeze. . my head hurts now but its still fun stuff.Likewise on the intake side. If the INTAKE manifold is a much larger volume than the piping leading up to it, then YOU WILL SEE A PRESSURE DROP.
So, it's quite likely that flow through the intake and/or exhaust haven't changed AT ALL. Rather, your means of measuring temps and pressures are being tricked by the the cooling expansion effect of a larger VOLUME-- both on intake, and exhaust.
Now, if your boost is being measured using one of PDRs Boost Bolts, then we're back to square one on the intake side.
