Thanks for the write-up. Just did this job to replace the blend door, mode door, and recirculation housing in my 2003. Sure made the job easier.
Some improvements that can be made anytime the
HVAC unit is removed are below.
1. Get a piece of screen and about 8 #6 x 3/4" pan head screws.
I used stainless steel screws to reduce the chances of rust.
I decided to use aluminum screen since I thought it would
be more durable. Fiberglass may be durable enough - that's
your call. Remove the outside air intake pipe from the firewall.
This is the piece that is rectangular and passes through the
firewall. Form the screen around the outside air intake pipe, on
the outside air side, and cut as necessary. Use the screws to
fasten the screen to the intake pipe. This will stop any debris
from finding its way into your HVAC unit. There was a good bit
of leaves and other debris in my HVAC unit.
2. This next improvement has not been tested, but it should work.
Consider using a very small bolt and two nuts (one on each
end of the bolt) to replace the broken tab on any of those
white bushings. On my HVAC unit, I have two of these white
bushings where the tab has broken off each of them. The idea
is to drill a hole through the bushing, right through the center of
the bushing, oriented so that the head of the bolt serves as the
plastic tab that breaks off so easily. Use the nuts to secure the
bolt at either side of the bushing. This distributes the force of
the door stop across both sides of the bushing rather than
having the force build up on one side as Dodge did. I was lazy
and did not perform this improvement, rather I purchased new
white plastic bushings from Dodge. Actually, I did not think of
the improvement until after the truck was put back together.
3. The mode door from Dodge has the same design flaw where the servo
is able to twist the mode door shaft before it hits a stop.
This is what causes the door to break in the first place.
The mode door on my truck lasted 75K miles - not too bad for
an American vehicle. This twisting is what breaks the mode door
shaft thus necessitating repair. What needs to happen here is
the stop on the passenger side needs shimmed. Once the passenger side
stop is shimmed, the servo can no longer apply too much force to the
shaft of the mode door. You can glue some very small washers to the
passenger side stop to correct this. I used JB weld and some small
stainless washers (perhaps #4?). If you shim the stop too much the door
will not close completely.
Hope this helps anyone that tackles this job in the future.
