Man I love this thread, lots of good discussion, thoughts and ideas.
Articat has it nailed on the head, what is important most of all is flow, not as important as pressure. If you've got a great fuel supply then 10psi ought to be plenty adequate, as long as it's 10psi under all conditions, all the time.
A while back I removed my stock lift pump and mounted it by the fuel tank pickup. I cut the stock plug off the wiring harness about 3-4" back of the plug so that if I want to put it back, I can resolder the wires and no D/C tech will ever "find out. " I then soldered 2 wires onto the stock wire and ran them back to the tank, terminating them at the pump. For now I used a strap and mounted the pump to the bed support pad. I used silicone gel on the plug to keep water out, and even though it was back there all winter getting hammered with crap and water, it hasn't missed a beat. I plan to get an aftermarket later on which I will mount "permanently. " The relocation seems to have added a bit of power, and helped fuel pressure by at least . 5-1 psi at the injection pump. In my opinion, unless you're a big BOMBer, the stock fuel line from the tank to engine bay are adequate if you are PUSHING fuel through it... woefully inadequate used as a straw
. I don't see the need to go 1/2" fuel lines from the tank if you have a good pump back there.
Brandon, regarding picking a pump to standardize on for fuel line kits, to mount at the tank. . . I think most aftermarket pumps use 3/8" NPT ports. So guys could choose between the Carter, Mallory or Holley and be able to use the same "kit. " Whatever pump becomes the "favorite," someone could do up a kit with mounting hardware, hose, wiring, etc. so DYI guys can easily relocate an aftermarket pump to the tank area. Like you need more work, right Brandon?
I got burned out on the fuel line kit stuff so turned it all over to him, but I still plan to contribute to the R&D department though.
Vaughn
'01 2500 QC Shortbed 2wd, 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBed: RV injectors, PS Boost module, Amsoil air filter, straightpiped exh. , Aeroquip 3/8" fuel line w/tank mounted lift pump, AutoMeter Sport Comp gauges, Line-X'd, Amber turn signal conversion.
Mildly BOMBed Performance: 0-60 @ 10. 0 sec. ,
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
[This message has been edited by Vaughn MacKenzie (edited 03-14-2001). ]
