I've seemed to have lost boost and power and can't find the problem.
With the stock injectors my boost would climb fast and peg 30PSI. I installed the new injectors and I did get a little more smoke but no real noticeable power increase. #@$%! But I did get a hesitation at light to mid power. I then found my 0-35 psi boost gage would only read to 30. So while waiting for the new boost gage (0-50 psi) I decided to put the stock injectors back in. With the stock injectors back in I noticed I had a hard time getting the boost to 28 psi and it would move up real slow and power was also down. After getting the new boost gage I put the DDP injectors back in and I got more boost but it only goes to 36 psi before leveling off 33 psi. This is with the turbo waste gate disabled. Truck will smoke good till boost kicks in then clears up with a slight haze at full throttle. I have 5-8 psi of boost at 70MPH which is what it did when stock.
I’ve checked:
Timing
Fuel pressure
Tightened all intercooler clamps & inspected rubber for cracks
Turbo waste gate is closing
Tried several AFC housing adjustment (spring, tension, position)
Tried cam plate in several positions
Checked all boost & vacuum lines. (Even replaced some)
New fuel filter
Removed fuel heater
Adjusted valves
New fuel
I have a strip of road I’ve been testing the truck speeds on when ever I add or adjust for performance. Its 2 tenths of a mile (street sign to street sign), up a 5% grade. Goes like this:
Stock = 54mph
Stock with stock cam plate full forward = 61mph
Stock with stock cam plate full forward w/transmission mods = 66mph
Added #10 & gsk = 75mph
Custom #10 (more off top) & meth = 85mph
Added ddp3 injectors = still 85mph and this were the problem started
I’ve talked with Piers and DDP and they seem to think my pump may have a problem. Could the demand of extra fuel from the new parts somehow cause a pump to go bad? The pump may have been on the edge of going bad and the extra demand for fuel may have put it over the edge. Any one else experience this? Anything else to check besides the pump?
I’ve checked:
Timing
Fuel pressure
New fuel filter
Removed fuel heater
Adjusted valves
New fuel
Stock = 54mph
