Engine/Transmission (1994 - 1998) injector pump tdc pin/plug
2nd Gen Non-Engine/Transmission worth how much ?!?!
Engine/Transmission (1998.5 - 2002) Turbo RPM Module
just some quick info please, I need to know which plug on the injecter pump is the top dead center plug. There is a plug looking thing directly under where the fuel shut off enters the pump. Then there is a metal plug just in front of that. Which one is the right one? I don't want to take off something thats gonna mess anything up.
Thanks in advance.
Warren
It is not a plug. It is a cap. It is a big hex cap with a rounded head and it has to bolts on either side. The top one is one of those non removable round head jobs. When every thing is at TDC you can pull the pin under the cap and turn it around and it will keep the pump at factory timing specs.
Treven.
