Engine/Transmission (1994 - 1998) Installing AirDog 150
Engine/Transmission (1998.5 - 2002) TRansmission SHops
Engine/Transmission (1998.5 - 2002) Fuel line frozen...again...and again.
I dropped the tank today to install the drawstraw. I have two questions. One, I notice the metal tube that installs in the filler neck hose is quite a bit smaller that the metal of the filler neck. This means that the hose will fit really lose on the metal and the clamps will have to be tightened down more to make the connection tight.
The second question pertains to the factory metal supply and return lines. I want to remove the line that I am not going to use. What is the best way to plug off the uneeded line on the fuel tank module? Thanks.
