What should the labor cost be on the replacement?
Warranty pays next to nothing so an hour is what you will probably end up with. It can be a DIY job if you have a GOOD torx bit and some dexterity
I would double check the intake air temp sensor. Mine was cheap to replace and cured the problem. If on the road and the heater grids come on - disconnect the wires at the grid or better at the solenoids.
The grid heater relays are de-energized once speed reaches 15 mph. They won't stay on once your driving unless the relays stick and you will find that when the battery boils dry or wires melt off.
The grid heater icon on the dash is controlled by the ECU and has no refernce to actually powering the grids. The icon coming on while driving and getting the dings is a diagnostic feature in the ECU indicating rail fuel pressure problems, thats what the OP is talking about.
So I have 6 new injectors ordered from my local injector/fuel pump shop ($280 ea. for Bosch factory remans. )
I'm not familiar with all the options... Sac nozzles? Larger stock tips?
