Background:
Earlier this week, my truck went into active regen. Haven't had the EVIC message on active regen for over 2 years. But Tuesday afternoon while taking my wife to the airport and stuck in rush hour traffic, my EVIC gave me the active regen count down. DPF 100% full, 90% full, 80% full, 70% full. Then after 70% it stopped active regen and said that regen process was complete. However, I suspect the DPF was still about 50%-60% full, but the truck decided that was OK.
I put a trailer behind the truck and loaded my wife's car on it. Drove it like i stole it.
Edit: The EVIC was dinging annoyingly the entire trip to and from the airport (except for the last 5 mins). Seemed like it was constantly going in and out of Regen. And every time it did, it dinged at me again. My wife told me to get that obnoxious dinging noise fixed. I think I did...... at least for a while?
:-laf
Sounds like truck micro-managing to meSo yesterday, i went and rented a uhaul car trailer for 4 hours, loaded my wife's car on it and put it on the hwy for a while. I did this for no other reason than trying to get the EGT's up.
You get the warning once the DPF is to a certain percentage clogged (90%? I don't recall exactly). This will only happen if the driving time/habits of the truck do not allow ample time for a passive or active regens.
Thanks, towing a 38' fifth wheel probably takes care of that, not a lot of city driving.
:-laf
Sounds like truck micro-managing to me![]()
The thing is.....you could have just driven around (preferably highway) without a load and it would take care of itself.....as apparently it already did. Active regen does not require the engine to be "worked".
I have done that in the past. But it takes a LONG drive to get any passive regen benefits and it didn't seem to have a lasting effect. On the hwy (without load), my turbo doesn't even seem to be doing much. Under a towing load, I was getting more turbo boost and i suspect higher EGT's.
I believe the active regen that it wwnt tbrough did not clear out 100% of the soot from the DPF. It counted down to 70% and then said "Exhaust regeneration process complete". But i believe the DPF was still 50%-70% full. Still had a check engine light after the active regen. But the towing I did took care of that.... and the CEL cleared itself.
If your truck needs an active regen, it will do it. It will do it without you having to load the engine, it just needs time, like a bit of highway driving. The extra heat needed comes from the added fuel from the injectors on the exhaust stroke. It does this without having to work the engine hard.
It looks to me like you are confused on what the terms active and passive regen are. Your truck will frequently go into active regen when needed and you will not get any kind of warning. You only get the warning if the truck hasn't been driven enough for an active regen to finish the job and the DPF has plugged to a critical point.
During a passive regen, your truck isn't really doing anything special......the ECM isn't calling for a regen at all. It simply means that the engine is working hard enough that it is generating enough heat on its own to reduce the amount of soot it creates, as well as be able to burn it out of the DPF.
It sounds like you are just going to "believe" there is a problem regardless of what your truck tells you......but do you see how illogical it is to rent a trailer and tow a car around to fix an imaginary (in my opinion anyway) problem?
Lol!, well 4wd certainly wouldn't have anything to do with it!
There isn't much load there from engaging 4wd. Some, yes, but it would be an imperceptible burden for a Cummins.....probably like driving an AC compressor. Certainly not enough to raise EGT's any notable amount, and even more certainly not enough to perform a passive regen.
There is much more resistance to movement (or "load") going highways speeds just from wind resistance. Wind resistance increases exponentially the faster you go.
I'm not going to argue with this statement. You could be correct. But it was a 3 hour trip (round trip) just to get to the dirt road on which i was able to get the RPM's up in 4th gear.
Edit:
I don't know why it posted this twice. But I wanted to add that it was 20-30 miles in 4x4 on the dirt road.
