When sampling oil it is a big no no to sample from the drain plug if you want an accurate sample. Sampling from the drain plug results in sample contamination, everthing over the years settles to the bottom of the pan even if you change your oil regularly. Five different oil sampling facilities I have dealt with have all given the same instructions, "dont sample from the drain plug".
