Please send me your photo's toOriginally posted by CPFF:
The 'patent stuff' is all taken care of. The reason I did it is because whenever I come up with a gadget, idea, etc. , I get harassed by the "experts" saying I should have patented it. Although I didn't think this had much commercial value, I looked into it.
I do have pictures of the jig and the process--I don't know how to post them. I can e-mail them to anyone who is interested in seeing them--I figured out how to do that.
rustnrot -- In answer to your question about aluminum chips getting into the motor--the trick I use is very easy to do on the B-series engine. I clamp a fitting in the bottom of the vent hose (the hose on the drivers's side that drips oil on the driveway). I then attach an air pressure regulator with a 0 to 15 lb gauge, attach the air hose to it and adjust it to 1 to 2 lbs MAX. This will charge the inside of the motor with air and, as the drill breaks through the casting, the chips will be blown out past the drill. After you drill the first hole (tap drill) you can increase the flow to clear the chips from the countersink and the tap. This trick also works nicely for finding those oil seeps. I pressure wash the engine, let it dry thoroughly, then hook up this pressure system and watch for where the oil seeps out. If I don't find it, I loosen the oil fill cap, run the engine for a couple of minutes to circulate the oil, shut it off, then try again until I find where the oil is coming from.
MGM -- Yes. As of now we will be crossing PA on I-80.
cl2repair@yahoo.com Your Idea has given us all peace of mind. Thanks again
Bill from PA
