1400 spoolup
BigBob, The Kwikspool with the 12cm2 spools up much like a stock hx35. (some say "Kwiker")I have not tested the Kwikspool in every combination but I am very pleased with the results. I will be mounting the latest model of my Kwikspool on my truck tomorrow.
I recently added several additional Heat and pressure probes (with test meters that record max and min readings as well as differential readings) into my truck so I can give more reliable information. I can now monitor Egt temps three places, Intake Charge air in two places and the drive pressure.
As many of you know it is difficult to watch and record several different gauges, Speedo, Rpm readings and hold on to a Bombed CTD powered Ram keeping it from eating every car in its path all at the same time!
I have run with a stock hx35 set to 40 psi for the last 2,500 miles to establish some base line #s. I hope to have numbers comparing that to a Kwikspool 12cm2 by fri or sat.
I know from past R&D that my EGT gauge climbs much slower and my max EGT's are as much as 200 deg cooler with the KSpool hx40. Over all the truck breathes much better. It will suck the Aircleaner vacuum gauge down to 35 with a clean K&N filter.
My goal with most of my R&D is lowering EGT's so we can use 400 to 450 hp while towing heavy trailers. So far I am very happy with the results.
For those interested I am selling the housings seperate for current hx40 owners and the complete KS Turbo setup for upgrading from a stock hx35. It will bolt right up with no changes to the exhaust and / or your existing exhaust brake.
My Email is
kwikkurt#@hotmail.com
and you can see pics on Chris's
website @
http://www.pbase.com/lstdr_2k1_rally/lstdr&page=all
