petersonj
What warranty did you have that covered you at 87,000? Mine was 70,000 as I recall and I lost my transmission at 74,000 (NV5600).
Factory warranty on the VP44. It was done in August of 2005. Bummer about your NV5600 transmission - they are tough transmissions.
If I am understanding your posts correctly, are you on your third VP44 injection pump?
My only concerns with frame mounted pumps is exposure to damage. We tend to get into some pretty bad situations where stuff under the rig could get damaged (going in the ditch or snow banks can do that. Messed up my 4WD actuator).
You could do like Mopar1973Man did and install the lift pump behind the rear axle. He had the same concerns as you and he has had no problems with his installation.
Regarding a gauge --- should I just purchase the adapter and splice it in my fuel line somewhere (where?) and then run the connection through the firewall somewhere? More details would help.
Whether a gauge or a pressure switch, the port should be at the inlet of the VP44 injection pump. A snubber is highly recommended otherwise a gauge or pressure switch will fail prematurely due to the high frequency pulsations from the injection pump. An electric fuel gauge will keep the fuel out of the cab - the sending unit will be in the engine compartment.
- John
