Loose Door Mount Mirror Repair
Need parking brake lever P/N: 52078289
Transmission yoke needed for 89 d250 5 speed manual
I had one of the power door mirrors (Passenger side) that wouldn't stay put in the mounting bracket so that freeway speed air loads or a good slam of the door would knock it out of the power adjustment range. I was able to tighten the lower bolt get it to hold still pretty well but the upper bolt had pulled the threads in the casting preventing a secure forward/aft adjustment.
There are two ways to repair the pulled threads. First (optimum) would be to install a Heli-coil thread repair in 1/4-28 and if you lack a plain old 1/4-28 (NF) tap and #3 drill bit and are going to have to buy a tap anyway the Heli-Coil kit will have it. Then replace the strange factory bolts with 1/4-28 x 3/4 socket head (allen head) capscrews on account of the small area available.
I don't have a heli-coil kit and they aren't available at the nearest hardware store but I do have a tap and die set and numbered drill index. The factory bolts are slightly less than 1/4" but have some kind of maybe self-tapping machine thread that is very, very close to 28 threads per inch. So close in fact that while the #3 tap drill barely removed any metal, the 1/4-28 tap cut just deep enough to get into fresh metal and the 3/4" length of the replacement cap screws I chose got into undamaged material.
I also had to run a 1/4" drill through the clamp that secured the mirror post to the casting that bolts to the door to allow the new bolts through.
So far the threads are holding and the mirror is staying put like it should which will be a vast improvement-especially when the slip-on extension mirrors for towing are installed!
If the threads are completely pulled there would have be no choice but to use a Heli-Coil or step up to a 5/16-24 replacement which was my first plan but I couldn't find a letter F drill bit-even though the hardware store has taps in that size.
Hope that helps someone else...
Great write-up. Good ol' fashion mechanicing...fix it with what ya got. None of the throw away and replace with something new and expensive if you can't find the un-obtainium.
Hey, thanks-that's a real compliment!
When I went through Airframe and Powerplant school the Mechanic/Technician debate was just getting to Aviation. The general feeling back then was that Mechanics fix things and "Technicians" remove and replace parts...
It's a shame but we have far too many Technicians and too few Mechanics-perhaps one of the reason for the Church of the First Gens-they attract Mechanics!
As hammered as this poor old truck is, I don't know how many times someone has stopped me to talk about it and not that many '90's trucks have that kind of following...
Well deserved! :)
Same thing evolved into in the military avionics segment as technology encroached. Tech (monkey, more like gorilla) - magic black box - banana - magic red button - push magic red button > light off - CND (could not duplicate) - get banana - light on > change part - get banana. The new guys had absolutely no idea what happened in the little black boxes, and the traffic control of them itsy-bitsy electrons through the "billions of miles" of wiring. We fixed the stuff with what we had...some interesting repairs kept them birds flying the best we could. Now electron tubes...well if a few quick thumps didn't "fix" them, then you'd requisition one from "somewhere else" and hope that acft didn't get put on the day's schedule. (Cannibalization authorization in progress)
Derrr...o_O
"Technician" for those delicate avionics jobs...;):) Will neither confirm, nor deny if this is a self portrait.:cool:
