Engine/Transmission (1994 - 1998) lost tach
2nd Gen Non-Engine/Transmission Rearend leak
Engine/Transmission (1994 - 1998) b1 turbo parts?
on holidays fuel solenoid went . fine wired it up temporarily, next day lost tach and speedo, lost amperage . changed crank sensor this morning, truck has been running a while to charge' still nothing after short drive. any thoughts. thanks, ron
Any surging of the tach up and down or is it completely dead? If you had surging I would say it was in the sensor or it's positioning (which should have been fixed with the new sensor). Since the alternater is RPM/tach driven you may not get a charge until it is up. If both are completely dead I would say it is up higher electrically, sorry I'm not much help when it comes to that. Hope this kind of helps.
Scott
The plug infront of the #1 valve cover can also work loose (happened on mine) and can cause it to go dead or surge.
Nathan
