Mag-Hytec 727-DD install
IceBox Intake
Magnaflow 5" Universal Pipe
I wanted more fluid capacity, so I got a 727-DD cast trans pan...
It comes with a "fiber" gasket that doesn't appear to be as high quality as the stock "overmolded" gasket on my 2003.
Does it matter which gasket I use? I'm leaning towards the stock one because it seems to be much higher quality.
Also, just to confirm... the 727-DD holds 4 more quarts than my stock 2003 stamped steel pan, right?
Thanks,
Louis
Most trucks can use the oem gasket once in a while there will be one that just won't fit 100 percent with the DD. The gasket that ships with the DD will work every time and is better than it looks at first glance
Bob
I'll go OEM every time. I have the M-H normal capacity pan (actually, I think it increases capacity a little) that I use with the stock/OEM gasket. I have dropped it twice for filter replacement and haven't had nary a leak yet. Not to say the one that came with the pan wouldn't work every time too, but these are my findings.
