I've got a 1997 4. 3L sea ray, and we're having a hard time starting it. Once it's warm, it starts and runs fine with no issues. Cold starts are a complete nightmare. It cranks and cranks, and doesn't even act like it wants to start... ... sometimes. Othertimes you give it one pump on the throttle and it fires right up. Warm starts are fine with no problem. It's hard to troubleshoot because it doesn't do it all the time, but when it does do it it's typically after not running for at least 24 hours.
I've found recently that when we're in the crank forever mode, a teeny shot of starter fluid will get it to fire and run perfectly. The choke looks like it's working, closing when I first start it then opening after it warms up. I don't know if it's tuned properly though. So it's telling me that I have an intermittent fuel problem.
And then, to complicate things more, occasionally when were in the crank forever mode, and I get angry and start pumping the throttle, it floods and leaves me sitting for even longer. So I'm kind of stumped, sometimes I have too much fuel, sometimes I don't have enough.
I'm considering a rebuild or replacement, but I want to make sure it's tuned properly and/or cover the basics first. I've found out that it's the Mercarb 2bbl carb on this one, I was wondering if anyone had any expereince with these carbs or this problem.
Thanks
Dave
Thanks
Dave
