2nd Gen Non-Engine/Transmission mickey thompson baja mtz
well I just wanted to tell everyone my experience so far with these tires... ... at 3000k miles replace 2 due to splits to the cords on the tire... and these were the front the rear two tires manly the power side right rear avery one of the inner tread block had small chunks missing so I should have stuck with my last tire but I tryied these. . so they have a warranty on them I guess I will be replacing these often I guess
I have a friend with a D-Max that replaced a set of those at around 5k miles for the same reasons.
They were AWESOME LOOKING tires... crappy quality.
FWIW, he went with TOYO MT's. So far so good, but only a couple thousand miles on them.
they would prob be better on a gasser. I have seen them on 2 ford 6. 0 and they look good but those fords dont have the torque that the dodge makes. . we will see what they look like at 6k miles. .
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE SMARTY TST PM3 MACH 4'S, RINGED AND STUDS, AFE/2:eek: "SILVERLINE D/PRICOL PYRO,BOOST,FUEL FASS 150, VULCAN 1/2 DRAW-STRAW, VULCAN 3/8 FUEL LINE AND FITTINGS, DSS 03 TRAC-BAR DSS BOX TURN-OVER BALL, RIDE RITE AIR BAGS. SUPPORT 17'' KMC BLACK HOSS, 315/70/17 MICKTHOM BMTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf
