Originally posted by JHammock
Mark,
The small plasma cutter is mine so if you need it other than Saturday, that is ok. In fact, it is at my parents house in Castalian Springs. It will cut 1/4" all day long. I ordered a circle cutting guide from Miller today, so I should have it Tuesday.
That's cool. I'm planning on getting the steel on Monday, then I will give you call about cutting on it some. That's very cool that you've already ordered the circle cutting guide, we can try it out VERY soon. :-laf Like I said this box steel I was originally told was 1/4" thick, but yesterday I was told it it actually 3/16" so cutting it shouldn't be a problem. I want to do some 45* angle cuts on the ends to make it flow better. I'm going to see if they can cut one end at a 45* angle when I pick it up though. Hopefully they will have something I can use to cap off the ends too, if not then I will find something at my neighbors mini scrape yard. Then all we have to do it cut some 4" holes in it and I can start collecting other parts... ... 4" pipe... ... 5" OD pipe/etc... ... clamps..... hmmmm I wonder if my old 34" long Miters will be long enough! :-laf Oo.
