Mounting horns on the ram
rehtaeW mraW
Amsoil: Positive Feedback!
Where did you put them? I want a set bad but i want a place that will have a nice clean appearance to it, I don't want to mount it anywhere on the body, just inside the engine bay somewhere. Thanks for the info
1999 3500 Flame Red Sport 5 speed, K&N, silencer ring MIA, Stickers removed, BIG CHROME CUMMINS POWER cab plate on the front fender, 4inch exhaust, 5 inch chrome tip, cowl inducton hood... stock for now, but more to come
I have mounted Hadleys under and behind the front bumper. Cant see them from the front and they are still loud as hell
Ditto on the behind the front bumper. I have a Grover and it will blow your doors off. #ad
Ron
'96 4x2 2500 Garnet/Driftwood Auto,3. 54,K&N,Cobra,Westac guages combo 50psi boost/egt, trans temp. Grover air horn, 93 TT Terry 29L,'84 VW Rabbit diesel, 67 VW bug.
Here is my 26 inch long Hadley mounted in the engine compartment with zip ties. If I need to move the horn to work on something I just cut the two zip ties and move the horn out of the way. Nothing to unbolt, had it mounted this way for couple of years now.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, 370s, AFC spring kit, Psychotty, Dunrite converter, Trans-Go, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn, PowerVision mirrors & 4" Stack Exhaust.
[This message has been edited by Koa Man (edited 05-02-2001). ]
What is involved in installing these things?
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
You need to mount a compressor, air tank, and horn somewhere on the truck. The horn solenoid can be fed directly from the 2 wires to the OEM horn. Feed the compressor directly from the battery or through a relay switched by the ignition. Use tubing to connect the tank, horn, compressor, and solenoid together. Rickson sells a Grover kit with all of the parts you need. Other suppliers have similar kits.
The installation details for my wife's 2001 Ram are posted here: http://dodgeram.org/tech/mods/01air_horn_kit/install.html
Dave
1994 2500HD 4X4 modified for off-road camping
2001 2500 ETH/DEE QC SB 4X4
Fritz's DodgeRam.org
I mounted the Grover compressor under my pass. side battery box. It vibrates the fender like the mother and sounds terrible.
I know that these things should be kept out of the weather, but any other recomendations for mounting would be welcome.
My Hadley compressor is mounted to the front of the passanger battery tray,horizontally( didn't even have to realocate the factory horns);no vibrations at all. The air tank is in front of the driver side battery. The whole installation took about 4 hours. I wired the compressor to an ignition hot wire with a relay activated by the grid heater light circuit( this way it will not drain the battery if it has to come on in winter)
I installed Hadley Bully horns & air tank in passenger side rear quarter with a Lexan shield (for snow & ice). Mounted the compressor to drivers side bumper support and ran air line through frame to the air tank. No noticable vibrations when the compressor is running. Horns are loud as hell. Hope this helps
KOA, you need to clean off those battery terminals.
1996 2500, 4x4, 5 speed, pscotty air, 15. 813 second 1/4 mile @89. 35 mph STOCK parts
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO BOILERS
I don't even use a compressor. I fill up a 8 gal. portable air tank to 125 psi. It is mounted in my cross frame tool box. (I have a flatbed) I have a 3/8 inch hole drilled in the bottom for the air line to run under the cab and into the engine compartment. This system is cheap, quick to mount, no vibration and of course no compressor noise either. You can get at least 20 or more 2 sec. blasts before air pressure will be down to around 100 psi, which is still REAL LOUD. This system does not leak air. If I don't use the horn for six months the air pressure in the tank remains the same. You can do the same if you have a cross bed tool box also.
Yeah, after I took the picture and was looking at the battery I cleaned them off. Should have taken another picture to post, but hey, you are supposed to be lookin at the horn and not the rest of my dirty engine compartment.
Has anyone mounted them anywhere else besides under the hood? With how loud these are I was thinking you could probably find a lot better places under the cab. What is your opinion on that?
B I G O R A N G E AMBER-FIRE (BURNT ORANGE) / BRITE SILVER 2001(. 5), 2500, SLT, Q-CAB 4x4, SWB, AUTO, 3. 55, LSD, TOWING PACKAGE
ADD-ON'S: LINE-X, 1/4" STEEL LONGHORN HITCH COVER, WESTIN NERF BARS, YELLOW-TOP OPTIMAS
Depending on road and weather conditions, I would think under the cab might get your horn either drenched with water or caked up with mud. Don't know how water would affect the horn... . probably not hurt it. Under the hood is real easy and keeps it clean.
