MPG WOES
White paint on turbo blade
PTO IDLE WIRE
You are about where you should be for your configuration. I averaged 17 mpg driving around town for the first time on my last tankful. I have got over 21 mpg on the highway driving 58-60 mph but that's pretty slow and not worth the tradeoff in time, at least to me. Towing: 9-11 mpg, depending upon variable geometric pressure to pedal ratio. #ad
Sounds like you got a good rig. I would love to average 12. 5 when I'm towing. I just went to synthetic in the motor which is why I believe my mileage figure went up. Maybe the same will happen while towing.
John
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
I have a '97 3500 4x4 stock and have seen 20 twice @72mph,19 twice but normal is 18-18. 5 empty @72. 75+ it drops considerable. Towing 29'Terry 5th & 17. 5'Crestliner on double axle trailer 9-11mpg. Either 5th or boat alone 15mpg. Montana mountain driving. Must be in the ball-park with the rest!
I now feel better about getting 18. 6 mpg average. That is driving on country backroads between 45 to 55 mph. Best mpg is 21. 4. Running stock tires.
96 3500 Feline deceased. Ready to upgrade. 86K. auto,3. 54,Ext. cab.
K&N air,Star wheel spun,silencer ring hanging on a nail.
Truck looks just like the truck on left side of page 6 issue 31.
Maybe the 4X4's are a little less likely to provide the mileage, but I'm satisfied with my 99 2WD 3500. Totally stock, auto/3. 54 and hwy cruise control operation produces consistent 20. 1 MPG. I do baby it to achieve that figure and will remain stock for towing isn't a problem either. Dave
