Muffler, Should I send it back?
Some Good Information on Locker and Limited Slip Differentials
Brush Guards
I just received my new Dynomax muffler from Summit today. There is a small piece of metal (probably from the welds) that I can hear inside it if I tip it from end to end. I don't think it is a crisis, but I just don't want the thing to rattle like h*** after I get it installed.
Should I send it back and get another one, or not worry about it?
Thanks for the help once again fellas,
Ryan
There is something rattleing around inside it
I'm thinking it will always rattle with the truck running. That would drive me nuts. I think I would send it back myself.
'97 Ram,auto,3. 54 lim-slip,4x4,smoothie,BD(TST)#8 fuel plate-slid forward,Prime-Loc,VDO Vision pyro/boost,HiddenHitch class V Magnum.
Cooker,
If you don’t send it back, then you will think any rattle you ever hear is coming from the muffler…and you will be very ****** off…not at Summit or Dynomax, but at yourself for not sending the **** thing back in the first place.
2001. 5 3500 QC 4X4 6-speed HO 3. 55 black
1998 Jeep TJ black http://www.nm4w.org/members/puffer.htm
sounds like alot of trouble, but so is tearing it back off and replacing it after its welded in.
"ship it"
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,Jardines 4" turboback kit,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
Thanks for the help. It's going back. I just really didn't want to wait, but you convinced me it is the best thing to do.
Ryan
Sounds like maybe a loose nut or washer or something from the install kit. Are all of the hardware pieces there? If not, try shaking it out. If not send it back for another one. You don't want that in your exhaust. It will drive you nuts, and be loud.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package,Tow Package,DTT's
VB,DD2's,EZ,HOT PE,K&N RE-0880
