How are your factory injectors holding out?? :-{} Mine are still good yet (jinx?)Operator error? :-laf
steved
steved
How are your factory injectors holding out?? :-{} Mine are still good yet (jinx?)![]()
Nope. I have a few probs with the "new" one. Called and talked to a guy who said they might give me another one, but I have to call back and talk to the right guy. I'll get around to that one of these days. Warranty is good 'til Sept I think so there's no hurry. Anyways... when I talk to him about this trans I'll ask if they keep records of the cores they get back. Maybe I can get a little info.Hey Now!!
Did you ever get an explanation of what caused you're missing teeth transmission?
btw they weren't missing... . I knew right where they were...![]()
What fluid are you running Jason?? Or did you already say??
steved
... replace with the CORRECT amount of amsoil...
Maybe you need to beat on the trannys some? like the motor? get it in gear and give it some WOT runs.
maybe try some diff modifier (stuff from napa works) with what you have now?
I had a problem with my transmission hanging up in gear, sometimes taking way too long to shift. That all went away with the new clutch.
For some time I've suspected the clutch assembly. . the disc was replaced under warranty for a "rattle" (sounded like a coffee can full of marbles). I am occasionally getting that noise again.
SBC Con OFE. Despite the thread that I started about it (dumb idea), it's been pretty good.What did you put in for a clutch?
The reason I have suspected the clutch is the fact that if I double clutch, or even bump the throttle (clutch depressed), it will drop into gear without a problem. I wonder if changing the fluid is just masking the problem?
It doesn't give me a warm/fuzzy thinking about changing that clutch though... my dad's NV4500 was heavy, can't imagine the NV5600.
The NV5600, which weighs in at 465 lbs. is rated to handle nearly 20% more torque then the NV4500HD five speed.
Taken from quad4x4.com
Merrick
