2nd Gen Non-Engine/Transmission Need a little help-speedometer problem
Engine/Transmission (1994 - 1998) Air in fuel
Engine/Transmission (1998.5 - 2002) HELP CHECK ENGINE Light
BSmalley
Hi all,
My 01. 5 seems to have developed a slight issue with the speedometer and cruise control. The other day I was travelling up the highway with the cruise set at 75. I went over a bridge expansion joint (good bump) and the truck took off accelerating. I tapped the brake pedal to shut off the cruise and went back to normal. However, I noticed that the speedo was going crazy with the needle sweeping up and down. Also the ABS light came on and off a few times. Over the next couple of days, the above symptoms have remained. After searching here, I think the rear wheel speed sensor is toast. I have ordered a new one but I cannot find where the sensor is located. Any info would be appreciated.
TIA
Bill
