Well my Drag UFM was becoming unresponsive and freezing so I called the good folks at Edge. No problem, send it in and we will send you a new one. That was on the 20th. Gethome today and guess what was waiting for me... ... . Wow that was fast
Anyways, I went out and installed it and decided to take a test spin. With the old box I was maxing at 57 psi... ... well with the new box I maxed at 51. :{ :{ :{
What now, did I have a "special box" before. It does so happen that I took off the High-Ram intake and re-installed the stocker but that cannot be the reason for a 6psi drop on 5x5. Needless to say when I got home I checked my intake bolts and cinched them down alittle more but I don't think it is a boost leak. One thing I did different this time that I did not before when I was at my peak was drive in 4 wheel drive. It has rained all day so my tires kept breaking loose when excellerating. However this shouldn't have any effect. Unless the ECM detunes the motor when in 4wheel but I don't think so. Hopefully on my way to work tomorrow the roads will be dry so I can try a couple of full throttle runs in 2wheel drive but if that doesn't help I will re-install the High-Ram. However everything I read tells me that the intake will not make a difference. It doesn't seem that my fuel pressures at WOT is any higher but then would 1 psi be noticeable? I am REALLY bummed out... ... .
One thing I will do is have a pressure test to see if I do indeed have a boost leak. But it looks like I will need to re-dyno and update my sig to some lower numbers. :{ :{
