Demons in the Cummins
OK, will try to answer all that in order. I made NO mechanical changes before the demons arrived. It was starting fine at the home of the guy I bought it from. In fact we slept in it at his place that night, and I started it easily the next morning to head home, 200 miles away. The first problem surfaced about 30 miles away, I stopped for coffee, shutting it down since it had no starting problems. Coffee down and it would not start! That was the start of the problems. I used WD40 for starting aid, it fired and off we went. An hour or so later, had to stop for bladder, but was smart, not going to turn it off this time! Fooled again, as I was slowing down for the turn into a truckstop, it died while rolling to the turn. Luckily I was rolling fast enough that with no power steering or brakes, I was able to roll it into a parking space. Lots of WD40 and maybe starting fluid, finally got her going again. It repeated this trick at a stop light later. Got it going finally, started the genset in case I was losing power to the solenoid (NO test tools at all along, big mistake!) It was getting evening, and the next 100 miles home were uneventful. The batteries were not the best, so I replaced them with new (it uses 5 batteries for starting). Still did not fully correct the problem, starting was an if situation, and continuing to get worse. The lift pump had been found to not pump fuel by the manual lever, so priming was impossible, then found out the lift pump was shot. Replaced that, primes easily now, but still had starting problems getting even worse. Decided that perhaps it was sucking air in the 36ft aging fuel line, wanted to put on a DAVCO unit anyhow, so did that. Eliminated any chance of air sucking, since you can pour fuel into the DAVCO directly. DAVCO is only a foot or so from the lift pump. The DAVCO actually replaces ALL the fuel filters, this setup originally had a "fuel strainer" on the tank side of the lift pump, and a dual filter setup on the pressure side of the pump. I have not yet eliminated the two secondary filters, but replaced them for the time being to eliminate them from problems. Obviously any leak there would be visible as a leak, since it is on the pressurized side of the lift pump, Suggestions were made to get the injectors serviced, so I pulled them, one was scored and stuck, the other five were in fine shape. Overhauled injectors installed and it did not help the starting problems of course.
Diagram of fuel feed, instead of drawing, fuel line from tank direct to DAVCO (DAVCO has a check valve in it in case you did not know that). Short line of a foot or so from DAVCO to lift pump (which as a diaphram also has a check valve). Steel line from lift pump to filter housing, thru two filters and on to injector pump. The dual secondaries was a customer ordered option from Cummins, and has a bleed screw in the housing. Fuel flow and pressure are quite adequate there. One can see from the lowering of fuel level in the open DAVCO that fuel is going into the injection pump, plenty of fuel. One can also see that there is no air sucking in, and no drainback (it would have to drain back uphill the way it is plumbed. ). One could suspect the short rubber hose type line from DAVCO to lift pump of course, but the visual of the bleed shows no restriction or air leaks.
I am next supplying full direct 12v to the stop solenoid, and after that a solenoid pull is to happen. After that, it seems to be pump time for the VP14 Bosch. Oh yeah, I am about to install a fuel pressure gauge on the filter output banjo bolt.
