New SMARTY touch to be released in November
Smarty Touch Update-
UDC for Smarty Touch
Bob Wagner
I would like to introduce our newest offering to the smarty family of products. Thank you
http://madselectronics.com/SmartyTouch.html
Smarty Touch features:
4,3" Touch Display. Resolution 480 x 272 - 16.3 million colors.
Two devices: Smarty Touch Display and Smarty Touch Controller each with its own CPU. The Display for the graphics & user
interface and the controller for communicating with the ECM.
Twin CPU design. The fastest Display & Tuner on earth!
Fastest display start up in the industry. Just four seconds!
Fastest PID refresh speed in the industry.
Fastest ECM download in the industry, up to three times faster than the competition, a typical ECM update takes 1.5 to 6 minutes,
depending on the model year.
Small micro USB cable connecting the display and the controller for easy installation.
MicroSD card for simple and fast updates (included).
Fully Internet updateable. Updates are always FREE!
MicroSD card can store multiple UDC custom tunes.
Works with any MicroSD FAT file system formatted card.
EGT sensor (optional). Reads accurately up to over 2200°F.
Four dashboards, each configurable with five different gauge layouts.
For details about the dashboard layouts please click here.
Freely configurable gauge(s) range.
Two alarms (high and a low range) can be configured for each PID.
Audible and/or visible alarms can be configured.
Configured ranges are also displayed through colored bars in all digital gauges.
Configurable PID refresh speed.
Each gauge stores/updates and displays the max reached PID value continously.
Recorded max values can be reset at any time.
Customizeable display background.
Adjustable sound feedback for alarms.
Supports over 300 SAE and Proprietary PID's.
For a detailed list of the supported PID's (depending on MY), please click here.
Works on all Dodge Cummins Ram Pickup's from 1998.5 to present.
For details about the supported truck models please click here.
CaTCHER software inside with ten power levels.
Selectable performance parameters for fine tuning.
Works with our UDC custom tuning software
Can store any number of UDC custom files. The only limit is the storage space on the MicroSD card.
ABS tire height updates in just seconds.
Cold weather 3 Cylinder High Idle enabled for 1998.5 - 2002 VP 5.9L trucks.
Not traceable in the stock setting. Smarty Touch leaves no footprint in all 5.9L trucks.
Manual High Idle is enabled in all softwares for CR 5.9L trucks.
Reads Diagnostic Trouble Codes in plain text.
Clears DTC's.
Reliable, it works off your OEM hardware.
Programmable Speed Limiter from 25 to 250 mph.
TNT-R and SSR software for CR 5.9L trucks (Requires unlock code).
RPM and Shift limiters unlocked with TNT-R and SSR softwares.
Power on Demand "PoD" for CR 5.9L and 2007 - 2009 6.7L trucks.
Smarty Touch User guide:
Click here for the User quick guide.
Looks very nice but is there any further tuning available for the VP trucks that is not available with the S03?
With the on board SD cards, there really is no memory shortage. Are there any plans to provide any other software modification or maintenance functions, like certain DRBIII® functions? In addition to the standard functions like changing tire height and reading/erasing trouble codes, I would love functionality such as being able to cycle the ABS brakes for the bleeding procedure, programming keys for the SKIM system, enabling transmission quick learn, etc.
Just random thoughts. But cloning the DRBIII® would be so cool...
Any plans for a better mount than the suction cup? I feel like my 06 already has huge bling spots on the a piller. I seems to me there's tons of extra room next to the hvac controls or to the left of the stick shift.
I have my Touch mounted on a Edge CTS gauge adapter in my Mopar A-Pillar single gauge pod. I like how it sits out of the vision but very easy to read.
There have been several questions about multiple UDC tunes on a Touch, so here is how mine looks. I have 3 loaded on the Touch. It's not shift on the fly, but still a easy and fast change if needed.
Some other things I have noticed the Touch does that the S-06 doesn't do is it keeps your PoD setting between tunes and remembers the tire size, even if you go to stock and back to a tune.
I do like a lot of the features, I realize we are old school but it would be refreshing for some added tuning availability with the VP trucks. I'd be a buyer.
I notice that it lists the EGT probe as optional, is that an additional cost or does it simply mean you don't have to install it?
Also is there any option in the works for monitoring lift pump pressure on vp trucks.
