Just for your info, I dont have the smoke issues with mine but maybe thats cause I am running B100.
JJPage said:OK. I have now been able to enjoy/experience the Smarty for several days on numerous settings. In MY OPINION sw#1,2,3 are excellent, driveability and the ability to stack with my TST at different levels works extremely well.
SW#4,5 are very strong all by themselves under full throttle or hard exceleration, but under light throttle my transmission hunts, TC locks/unlocks, throttle response is erratic. When I add TST, full throttle is COOL!!!, but once again under light throttle, response(in my opinion) is too drastic and erratic.
SW#6,7,8,9 at WOT are just what the Doctor ordered Oo. If you add TST it only gets better, however, and I have to keep saying this is "my opinion", under normal driving conditions(light throttle) these settings are awful. No matter how easily you try and feather the throttle, taking off from a corner you bark the tires, throttle response is way too severe, transmission behavior erratic, I cannot relax and drive normal on the higher settings. end up with your soda pop in your lap.
Again, this is my observation and my opinion, I know some people want exactly what I do not. If I had to choose between the Smarty and the TST... :-{} TST would win out(ease of changing prog on the fly for 1).
I know Bob/Marco are listening and want objective feedback, They want to make Smarty better.![]()
lostronin said:So ya stack TST and Smarty but one fine day it's off to the dealer. Does reloading the OEM software from Smarty erase all traces of TST as well??
mattymac said:The TST shouldnt leave any traces in the ECM since all the info its recieving from it is just minipulated back to stock values, the ECM thinks its doing nothing diffrent because of the fooled info its recieving from the TST. If you have a probe for an EGT on the TST then thats a dead giveaway when there is a hole in the manifold with a plug in it.
I dont have any of these problems, you really have to control your foot, it took me about a week to learn how to drive with the smarty and all is well.CRiggan said:I agree with you WOT, with my sps62 turbo, 3flow injectors and modded cp3, I can smoke out the traffic behind me when leaving the stop light on any setting on the smarty with the tst at 0/0 or 4/4 .
I would really like to see the smarty have custom programming per user. But I also think with modded trucks like mine the ideal setup would be :
Modified torque management like we have now with no fueling until the turbo hits 6 to 8 psi or so.
And somehow get the trans to stop hunting for 1st to 2nd back to 1st when leaving the stop light with a light foot.
JDerbedrossian said:I dont have any of these problems, you really have to control your foot, it took me about a week to learn how to drive with the smarty and all is well.
Jake
Jake
AK RAM said:I think it would be better if we got half our go pedal travel back. For instance, assign go pedal travel a number between 1 and 10. 1 being idle and 10 being WOT. Well, anywhere between 3 and 8 the go pedal is the same and seems to make no difference where you put it. Just a little go pedal puts you at 2500RPMs as though you mashed it to the floor. Give it 3/4 go pedal, let RPMs come up, and slowly back off the go pedal and you have to get almost back to idle before the truck cuts any fueling. It is almost like your not getting more low end fuel, your just feeding the ECM more APPS signal at initial pedal travel so the darn thing almost goes WOT just off idle. Smoke would be much easier to control I think if we had half the available fuel at half throttle instead of all the fuel. Did that make sense?
