Question on the transmission relay switched power side.
I have 12v to relay from battery but on the 12v to relay from ignition switch I get a 12v volt flash of power then goes away. So no power to plug at top of transmission with key on, but I do have 12v when running.
Is this normal, from what I have read there should be switched power to the relay. This is for a 98 12 valve 47re
