Put a new clutch in my truck a few weeks ago when I swapped the NV4500 out for G56. And ever since I have been real close to not having enough clutch pedal to disengage the clutch fully and it starts engaging less than a 1/2 inch off of the floor. It's driveable. As a matter of fact as long as I'm careful it works fine... but when I don't think about it or get in a hurry the truck lets me know about it:-laf
A quick fix would be to simply lengthen the push-rod on the slave cylinder or work something out to make the rod on the master cylinder adjustable. I'm tempted to attack if from the bottom as adding a 1/4 " or so to the push-rod on the slave cylinder looks to be the easiest approach... but by cutting the master cylinder rod in half, threading both ends and adding a sleave I could more easily adjust it in the future.
Not sure which would be better
The Hyd system is still in good shape, no leaks or air, otherwise I would look at a new system.
