NP241 HD- Got the extension housing off...
There are 2 snap rings around the output shaft that retain the bearing on the shaft and one snap ring seated in a grove around the outer bearing race that retains the bearing in the housing (or the housing on the bearing depending on how you look at the problem). If you look into the snap ring opening with a mirror you will see the ends of the ring you need to spread. If you look into the end of the extension housing you'll see the outer bearing retainer and be fooled.
I took a pair of ordinary external snap ring pliers, heated and and bent the tips to about 45 degrees. The original problem was that I was trying to remove the outer bearing retainer through the access cover and not the extension housing retainer... I did not look with a mirror until the folks at GV told me
I've tried all the tricks I know (short of removing the T-case) to remove the snap ring in the extension housing of my NP 241HD transfer case. none of the snap ring pliers I have or seen fit through the access slot because the outer race of the bearing covers all but about 1/8 the of the slot. Has anyone come up with method or tool that might help? Thanks!
