I purchased said gasket. Part number 3957650. It came with a notice from Cummins that says " The new design provides of improved sealing and clamp load retention over previous design. " It also says" The old style gasket must be used on engines built prior to the engine serial numbers listed above or a coolant leak from the cylinder head will occur. " It looks like a regular gasket except it is missing a small hole it front exhaust side and has an extra compression limiter in front on the exhaust side. Cummins topic number 04T2-8. Have a nice day.
