I have a early 98 dodge 2500. The oil pressure guage in the cluster goes haywire when not pressing the throttle. Sitting at an idle at a redlight or in a parking lot the oil pressure will drop down to zero and the light will come on, then it will go back up to around 40 by itself. If it ever drops down to zero and you press the throttle it will come back up to where it is supposed to be. Or if you are sitting at idle and the pressure is like it is supposed to be and you pull it down into gear then the pressure will drop down to zero for a few seconds and will go back up by itself. If just does this spontaneously and sometimes it wont do it at all but it is starting to do it more often now. I have already put 2 different oil pressure sending units in the truck to try to cure the problem but it persists. Does anyone have any ideas as to what my problem is? It kinda acts like it has a short of some kind. Do you think that it could be in the guage cluster? I know that the truck has oil pressure because I have put a manual pressure guage in it and the pressure stays the same when the truck acts up so I know that something is just making the electric guage go crazy. Any help with this would be greatly appreciated. I am about to run out of options here. Thanks alot
