just a few things to rember
When you were a novice driver you were taught NOT to run in
5th. under or 1st. over when pulling hills or sit at the stop light with the clutch in,you waited till time to go and used the clutch
brake to pull into gear and leave the stop lite. Whens shifting gears you only pushed the clutch in a little over half way so as not
not bump the clutch brake and wear out the clutch brake to soon!
when going down long or steep hill's you held a slight throttle
pressure so as not burn the D or DD fuel pump discs,this was before the PT pump,some one spoke of a dime in the fuel return line,the dime had a hole in it to slow down the fuel return to the tank! Next time we will talk about the bad boy stinger for the PT pump. so long for now, GWD
