Now that the drive pressures have been measured... . the kit proves itself once again. Nice work!
Matt
Matt
Originally posted by Mark_Kendrick
I've spoken to Piers himself before and he was at least as forthcoming with info. Thanks fellas!!!!!!!!
anyway, back to the twins... ... ... ... .....
Originally posted by HoleshotHolset
This is a rounded figure, but that . 81 A/R is probably like a 11 or 12cm² housing... .
A 1. 15 A/R housing is pretty darn close to a 14 or 16cm² housing... .
Sounds like someone has himself a Garrett... . or a Garrett spin-off... no pun intended.
Matt
Originally posted by KatDiesel
What he did is fine and dandy and creative... more power to him. However when he intends to sell this setup to someone (yes they have been listed in the classifieds since 9/30/02) then drive pressure should be one of the first things tested. When playing with turbos the drive pressure will tell you alot. You don't need a baseline to compare it to... ..... you simply measure the combination and see if its working effecently or not.
I would imagine most poeple don't ask what drive pressure is like when buying turbos, because they either don't care or don't know what it is and how it is important. Drive pressure was discussed when I purchased my turbo.
Originally posted by StakeMan
So what was your drive pressure?
