P-pump converson question
Injection pump de-fueling too soon
transmission cooler (Just noticed today)
ok finnly got everything one question I still have is will the p-pumps gear fit in place of were the ve pump's did or do need the cam and crank gear off a p- pump also thanks George
you can reuse your crank and cam gears. you need the P pump gear and gear case, and stamped steel cover. Also the P pump support bracket.
