I've been seeing an oil leak under my truck for the last 70,000 miles. :{ Just turned 120k this past weekend. First it was the crank shaft seal on the gear case cover. Fixed that when the kdp was tabbed. 2nd was a few of the valve cover gaskets and replaced them, no biggy. 3rd was the gasket between the gear case and the block, (cha-ching). Next was the o-rings between the power steering/vacuum pumps, fixed them. Now it looks like its losing oil somwhere on the underside of the pump. It doesn't look like its on the forward end, more down under the AFC housing, but down below, not at the housing. I checked with a mirror and light yesterday, but couldn't find anything specific. I thought it might be the back cover as that has been off before
but it looks dry/clean. Everything under the pump including front axle, frame, chassis parts, etc. are coated and dripping. Are there any problem areas I should look for specifically? I'm almost reluctant to fix it cuz as soon as I do, I'll have another leak somewhere else. :-laf
