Well I think for the first attempt at Towing twins it was a big success. For some reason which I learning about now it didn't show an increase on the dyno but temps are down and speed is up in the hills so that tells me it is in deed working. The system seems to really shine as you get into higher elevation although the max boost does drop it starts out so much higher that your boost is where a good single would be at sea level. It normally runs between 45 and 50 lbs at 1200 degrees at 1000' and below and at 4500' it runs between 35 and 40.
Cliffman and I usually run about the same speed up most grades but this trip (we now run 1200 degrees instead of 1300) I can just walk away from him with the twins. I will be trying a few more combinations soon to see if it can be improved on but so far I would have to say it is a very nice improvement.
The daily unloaded drivabilty of the system is far better than any larger than stock single I have ever run. Remember I am still running a stock head gasket with studs and 55 lbs max boost so far no problems. This is to keep the cost of adding twins down for the average guy or gal who just wants the added benefit of twins and doesn't need huge boost.
Thanks so much to Piers at Piers Diesel Research and Jason at Northwest Custom for helping me with this project.
