2002 Dodge Ram 3500. EDM injectors stage 2, Edge Comp box, PDR HX 40, Scotty 2, 4" exhaust. PRYO, Boost, and FP gauges, Bombed transmission.
Hey guys was out in my truck last night with the EDM's and all and I can't seem to get my boost to work as you guys said a 40 would. If I get on it the boost climbs to 30 quick and if Im really in it A LONG time then I can get it to top out at 36 so I think I need to adjust the wastegate to 40 psi. I would ask piers how but the time zone screws us up. I also thought that the 40 would just zip right up there when you got into it mine if its at say 8 psi and I get on it, the thing will charge to 30 and sit there till it hits OD then I gotta back outta it cause my EGT's are approacing 1500 degreese pre turbo. Is this normal? Im afraid to keep my foot into it! Cruising EGT is about 600 but if I get into it with my EDM stage 2's and my comp on 4 or 5 my egt's soar to 1400 in like 3 seconds, then I back out of it because Im afraid they will keep going. The most boost I have seen yet is 36 PSI with the 40 Im hoping and adjustment will cure my problem. By the way what EGT can I run before it will burn down?
