I am putting in a new PS pump (higher output) and will be adding a cooler to the low pressure return side to keep it cooler. I see there are two return lines in the hydraulic system. One from the gear and one from the brake booster. Do I need to run both return lines through the cooler or just one of them? If I plumb both through the cooler would I need to worry about flow volumes and use larger fittings and a larger hose diameter between the cooler and pump reservoir return fitting? TIA.
-Deon
-Deon
