I picked up the Snap On SP144 fuel pump wrench and decided to play with a little more advance. My pump timing was already set at 1. 5mm by Piers when my wife and I drove through the area this spring.
Before I advanced it myself, I was hitting 1300+ deg. empty, no problem, and about 26 psi boost (also empty). Keep in mind that I have PW injectors and a PDR HX-35 with a non-wastegated 16cm2 housing.
Piers' advancement to 1. 5mm resulted in a little less than 1/8" difference between marks on the pump and gear case. He'd mentioned that when I pulled into his shop, my timing had been 1. 31mm.
I wanted to rotate the pump about 1/16" further and see what effect it had on things. There was barely the slightest difference in sound, so I'm pretty confident I'm still within the safe zone. But there was a dramatic difference in boost and EGT. Max boost is now 17psi, and I can't get EGT higher than 1000 deg. (and both of those are with a 1200 lb. camper, up a hill!).
There is also *zero* smoke now, even at full throttle (it used to leave a nice gray haze behind).
I know that advancing pump timing generally reduces measured boost and EGT, but I wasn't expecting that much of a difference! Do those numbers sound reasonable to those of you who play with pump timing quite a bit?
Thanks,
Mike
Thanks,
Mike
